Running a 160ft direct bury line to well shed
Old 10-01-14, 01:45 PM
160ft from panel to well site. Pump is 8amp max at 240V (as indicated on pump). I plan to have a light and plug at well shed. Also, an small 500W electric heater to keep contents above freezing (water line, pressure tank etc.).
I was online using those voltage drop calculators for a 15amp or 30amp 240V service to well shed. I understand I want to keep below 3% voltage drop. I figured #8/3 Teck cable should be good, but I am getting nervous that it may not be large enough. If I go larger I run into problems, like the Square D circuit breakers only accept #8 or smaller....oddly, the neutral and ground bars accept #6.
Appreciate help to break me out of my brain loop...
Old 10-01-14, 01:57 PM
ray2047's Avatar
If you are going to have both 120v and 240 volts you will need a subpanel supplied by a 3-conductor cable or four wires in conduit. A 30 amp breaker and #8 would work. (#8 will fit a 30 amp breaker.) You can use either 3-conductor UF-b or conduit with four #8 (one white, two black, one green).
Above based on US coded. If Canada requires armored cable then TECK may be appropriate.
Old 10-01-14, 02:34 PM
Yeah, Teck #8/3 is three 'conductor' (black, red, blue), with a ground (unshielded). They don't include ground in numbering.
I keep getting 3.1% for 30amp at 240V for that 160ft run.
The problem with Teck, other than it costs a pretty penny, is that it is a one shot deal. If I was doing PVC conduit, I could replace wire without ripping up 160ft of my yard....
Old 10-01-14, 02:43 PM
ray2047's Avatar
But you need a white. I doubt Canadian code would allow you to redesignate the blue white.
Old 10-01-14, 03:28 PM
Yeah, can use blue for white...just have to tape it white. The gauge just has to be same as other conductors.
