suspended wire
Received 0 Votes
suspended wire
i need to run wire overhead from a building that is 30' tall to a pole to put up a led light that is 90 watts length of span is 80 feet do not know what type of wire to use.
Welcome to the forums.
You would use 14-2 UF cable and a messenger wire. The messenger wire can be that 1/8" cable with the plastic coating on it. Sometimes it's called aircraft cable.
You can tie the UF to the messenger cable.
Received 0 Votes
I would suggested going to an electrical wholesaler not (Walmart or Home Depot), and explain to them what you have, they should be able to help you.
To elaborate a little, you need more information such as the type of pole round, square, steel or wood. Maybe this will help and give you some idea what you’re looking to do. What you basically need is a couple of what we call insulators, you attach these to your poles to tie your cable off, you can use #10 solid wire to tie the cable off, but I wouldn’t suggest this unless you have done it before. I think today they make a cable cinches for this. The cable you need is 14/2 UF sunlight resistant cable no guide wire required. Basically that’s it except for what you need to make your connection at each end. Oh and make sure if you’re in traffic area to be high enough with cable.
Good luck
Good luck
