gfic breaker white wire question
Old 10-03-14, 03:28 PM
R
I install a new gfic breaker in circuit box. It has white wire which I attach with the rest of the white wires under the screws. I noticed that many of the screws on that row of white wires did not have wires under them. The screws were only halfway tight, but no wires under them.
I started tightening up those screws that were half torqued then realized maybe there was a reason they weren't all the way screwed into the row.
Is there any harm tightening those screws down without wires attached to them??...
lol, hopefully I make sense.
Old 10-03-14, 04:19 PM
chandler's Avatar
Received 9 Upvotes on 8 Posts
They come from the factory loose. No harm. Your coiled wire on the GFCI goes to the neutral buss, while the corresponding white in the circuit is attached to a location on the gFCI under the hot wire. Make sure you have it wired properly.
Old 10-03-14, 05:36 PM
R
ok thanks Chandelier for your help..... that's what I was thinking , I was worried I did something wrong by tightening the lone screws snug against the metal row.
