Confusion on Switch
Old 10-05-14, 09:51 AM
D
Confusion on Switch
We just had the siding done , and took out a second entrance door , and I am having a time rewiring a switch for a hallways and stairs . It's a box with four wires as such :
1-Hot wire , its the only wire on this circuit breaker .
2-Dead wire to old outside light and outside receptacle .
3-Single receptacle on wall .
4-Wire leading to two switches and two lights , switch and light downstairs , switch and light down stairs .
I leave off the single receptacle , but no matter which way I wire it the lights do not work . I am fairly certain that the receptacle and old outside lines do not factor in , any thoughts before I call an electrician ?
Old 10-05-14, 10:01 AM
Received 3,897 Upvotes on 3,494 Posts
Welcome to the forums.
If it has multiple wires in it..... it's called a cable.
You have four cables that come to that box. Are they all two wire cables ?
(grounds aren't counted)
Old 10-18-14, 08:58 AM
D
Yes , one dead to old outdoor light , one live from the circuit panel , then the one that goes to the two lights/two switches . Sorry about the delay , with twins and a six day a week job things fall by the wayside .
Old 10-18-14, 09:23 AM
Is it still needed ???
You should be able to connect all the blacks together and all the whites together. That should bring everything on. If you aren't using the outdoor light any more..... don't connect that cable.
