Rechargeable Battery to run small fan for up to 8 hours?
Old 10-07-14, 07:07 PM
K
Hey there, new to the forum, I have a project under way and I am nearing completion but I'm at a stand still on powering. This is a DIY PAPR(Powered air purifying respirator) and I have done a few 12v dc powered ones but want to do a battery for this one and make it job functional.
This is the fan. Takes 4 Ds which is more weight than I'd like(bulk too). I would like it to have strong flow still but longevity in the battery or the option of a second set while the other charges.
Similar to this on amazon but mine takes 4 d cells vs 6.
Thanks in advance techies! I'm stumped right now lol
Also feel free to suggest other alternatives for fans(small, light weight, move lots of air)
Old 10-07-14, 07:20 PM
Received 3,885 Upvotes on 3,482 Posts
Welcome to the forums.
Do you get enough time out of a set of standard or alkaline D batteries ?
I would recommend a 6volt lead acid battery or a gel cell. The size required is based on current draw and running time required.
A 6v 1.2AH may work for you. Next step up is a 6v 4A. Basically same price but bigger.
6v 1.2Ah SLA Rechargeable Battery - F1 Terminals: amazon
Old 10-07-14, 07:30 PM
K
Thanks - about 4 1/2 hours on 4 ds I tried just to see. But as said thats a lot of bulk, and batteries add up$$ lol I'm just looking for a better (rechargeable) option. I'm also wondering if a small pc fan, like this is a better option?
Old 10-07-14, 07:40 PM
A fan is not quite the same as a blower. That little fan will deliver air but not under pressure.
You would have to try it in your application.
Old 10-07-14, 08:22 PM
K
I know what you mean, I think the motor will be the achilles heal of it. It may not be up to it, but this is what I did so far. 3-9v batteries push the air fairly well, is there a way to make them run stronger? I can't remeber something to do with the wiring of them. Series or parallel or something.. put it inside in place of the large blower.
Old 10-07-14, 09:08 PM
9v batteries aren't really the way you want to go. They have extremely limited life in this application and the rechargeable ones are not much better.
Old 10-07-14, 09:31 PM
K
Yeah thats what I'm reading too just too short of life. I put 4 9v on this little pc fan inside the old blower housing and holy cow she blows. Even with a 3m filter attached. This is good. Now I just need something compact and powerful to replace the 9v batteries.
Old 10-10-14, 11:11 PM
K
Bump. Just seeing if anyone else out there knows
Old 10-10-14, 11:33 PM
Knows.................. what ?
I gave you a good source of inexpensive and reliable power in post 2.
If you want to get involved in miniature hi capacity power cells then your going to need a custom charger.
