trench for conduit to garage
Old 10-08-14, 06:50 AM
Z
I am considering replacing an ancient 1" rigid that goes to garage. I would use PVC. I would like to utilize the same hole in the cement foundation.
Should I be looking to expose the current conduit and removing it and using the same trench or should I just dig a new one?
Old 10-08-14, 07:06 AM
ray2047's Avatar
I doubt it would be possible to remove the RMC from the concrete. Why not run the new conduit up an outside wall? Or you could rent a core drill to drill a new hole in the slab.
Old 10-08-14, 08:08 AM
Z
In that case it might be best to just go up a few ft' from the penetration in the cement and go out a sill plate with an LB and then get it underground outside instead.
Old 10-08-14, 09:13 AM
CasualJoe's Avatar
Received 185 Upvotes on 166 Posts
That's what I would do at both ends.
