4-way wiring issues please help!!
Old 10-13-14, 05:54 PM
B
I have two sets 3-way switches that control one light each. Two of the switches are next to one another. I would like to connect them with a 4-way switch so that I can control both lights, from all three locations.
I am not sure which wires I need to connect to the 4-way switch, and which I need to tie together with a wire nut. Each 3-way has a hot, and 2 other wires.
Any help would be appreciated!!Name:  IMG_20141012_210206482.jpg
Old 10-13-14, 07:46 PM
Received 3,885 Upvotes on 3,482 Posts
Welcome to the forums.
A three way switch has two travelers and a common. At one three way switch the common is the "hot line" in. At the other three way switch.... the common is "switched hot out" to the lights.
Right now you have 4) three way switches. You have two of them in the same box. You can't just randomly connect three way circuits together like that.
Old 10-13-14, 07:51 PM
ray2047's Avatar
Post moved to Electrical.
Old 10-14-14, 06:29 AM
A
Received 272 Upvotes on 248 Posts
This is what you need:
Three wires from switch #1 to switch #2.
Three wires from switch #2 to switch #3
Two wires from light #1 to light #2
Two wires from one light to one switch (not the middle switch).
Power (hot and neutral) to any one light or any switch other than the middle switch.
Chances are you will need to run a new 2 wire cable between the two lights.
You would need to trace the wires you have to see whether you havet he wires for all this. They make tone generating and sensing kits for this purpose.
Hint: Do not unhook any wire without first labeling it where it was connected to.
* The 2011 National Electrode Code calls for a neutral in each switch box. Depending on how the power gets in it may be necessary to have an additional wire daisy chaining through the various boxes over and above the aofrementioned.
Old 10-15-14, 05:59 AM
A
New question: (multiple choice) Where does the power come in to feed the existing 3 way light and switch setup?
a. At the light fixture.
b. At the box (pictured above) where the two switches one for each light are located.
c. At the other switch box.
(separate answer for each light)
Old 10-15-14, 06:36 AM
A
Received 159 Upvotes on 132 Posts
Since you have not specifically told us how many cables (containing how many conductors) come into each box nor does the picture really show this the answer to your question is: can be from any three of your selections. As mentioned as long as one common screw on one switch has a hot going to it and the other switch common wire goes to the light the power can be coming from either of the switches or the light. We can't tell from info provided.
Old 10-15-14, 11:18 AM
Received 16 Upvotes on 12 Posts
to the original poster ..... I'm sorry to have to say this but by the very fact that you have to ask this question .... you shouldn't be messing around with this. AND .... I don't know about the rest of you but do you really want the responsibility of trying to tell someone how to do this in this format?
Just my opinion.
Old 10-15-14, 02:38 PM
Jimmiee.... read some more threads at DIY. A homeowner has the right to do any thing he wants in his own home. The OP asked a question. He has the right to get an answer. Based on the replies that have been posted he may just decide that it isn't worth the aggravation or is beyond his comfort zone.... the decision is his to make.
We are deal with potentially hazardous subjects in almost every forum. The poster needs to recognize the limits of his abilities.
