sealing an outdoor light fixture
Old 10-14-14, 01:11 PM
I have a light fixture outside that has some gaps around the mounting base. You can see into the siding . Is silicon caulk appropriate for sealing that gap between the fixture and the siding? Or is a putty more appropriate?
Old 10-14-14, 01:22 PM
P
Received 1,759 Upvotes on 1,572 Posts
I would use a caulk either a silicone or water based acrylic that's paintable.
Old 10-14-14, 02:56 PM
Tolyn Ironhand's Avatar
Received 672 Upvotes on 570 Posts
I also suggest caulk, but leave a spot at the bottom of the base caulk free so that water can get out.
Old 10-14-14, 08:00 PM
pcboss's Avatar
Received 163 Upvotes on 142 Posts
That may be a sign the fixture is improperly mounted and needs a siding box.
