Low voltage cables question
Old 10-15-14, 11:19 AM
R
The low voltage cables for my Air Conditioner and Furnace are run next to each other. I was putting up a drop ceiling and I zip tied the two cables together. Is there any harm in doing so?
I would guess no, but I wanted to make sure.
I also zip tied a portion of the cable to metal conduit with line voltage wires inside of it. Is it ok to have low voltage cable running along the outside of a metal conduit?
Old 10-15-14, 02:18 PM
Received 3,884 Upvotes on 3,481 Posts
Cable tying the low voltage wires together is fine.
According to code..... no wires are to be fastened to the outside of the conduits.
Old 10-15-14, 04:38 PM
Tolyn Ironhand's Avatar
Received 860 Upvotes on 723 Posts
Low voltage control cables that are controlling equipment, it is allowed to be supported by the conduits that is serving power to that equipment. 300.11(B)(2)
