Hooking up 2 way switch to 3-way
Old 10-16-14, 01:22 PM
E
Hi,
I'm home helping my mother. She has a 3 way switch wired at the top and bottom of her stairwell. "They" (Don't ask) put in a double box because she said that she would like some decorative lighting on the wall at a later date.
Problem: They only ran, and hooked up, the 3 way wiring. I tried to explain that while the common wire would work for power, the neutral changes every time the opposite switch is turned on/off.
I can't think of a workaround. Running current through the ground is not according to code anywhere, from what I can tell, although ... that would work. AM I going to have to try and fish new wire through the stairwell wall/header? Not the fun I had hoped for this weekend.
What do you think? Am I as stuck as I think I am?
Thanks,
Signed,
I am up wiring creek fighting the current all the way.
Old 10-16-14, 01:35 PM
Received 1,267 Upvotes on 1,207 Posts
Welcome to the forums.
Where does the power come in to the switch boxes - the one without the double box?
Old 10-16-14, 01:44 PM
E
LOL. Already thought of that. The powered end of the 3 way setup is at the other end of the stairwell, and in the basement.
Old 10-16-14, 02:14 PM
Then I think you're going to have to run a new cable.
Old 10-16-14, 02:28 PM
ray2047's Avatar
Terminology: 2-way switch is what they call a 3-way switch in the UK. The term has no meaning in the USA. Call it a regular light switch, SPST switch.
No, it remains the same. A neutral is never switched. You were close though. There is no neutral at the top. May not be a neutral at the bottom either depending on how it is wired.
You need to find a source of power for the new light such as a nearby receptacle.
Old 10-16-14, 06:38 PM
CasualJoe's Avatar
Received 185 Upvotes on 166 Posts
They put in the double box for additional "future" lighting. Are you sure they didn't also install a power cable to the double box for the future lighting?
