Main breaker panel breakers movement when pressed.
Old 10-17-14, 03:54 PM
F
How snug should breakers be?
I was surprised when I pressed on the outside edge of a breaker that it moved a little.
I thought maybe it's not inserted all the way. Took the cover off and checked that it is fully slid into the tab on the outer edge and that when pressing it towards the inside that it is in all the way.
It looked just as all the breakers do. So I pressed on all the breakers and they wiggle just about as much as the first one.
I've never messed with my box before so I found this surprising.
Is this normal?
These are this type of breaker:
Siemens Recalls Circuit Breakers Due to Fire Hazard | CPSC.gov
Of which I had found a recall for Siemens breakers. I'll have them checked out to be sure they aren't of the batch of bad ones.
Good thing I looked this stuff over. Just moved here recently and I'm really ticked that the home inspector missed a few things.
I noticed that there are 2 20 amp breakers that are on 15 amp circuits. Wow. I think if there's one thing he should have checked, was that. Waste of money.
Thanks in advance for any reply.
Old 10-17-14, 04:56 PM
pcboss's Avatar
Received 163 Upvotes on 142 Posts
What were the 20 amp breakers feeding?
Old 10-17-14, 06:09 PM
Received 3,424 Upvotes on 3,070 Posts
It's normal for the breakers to fit loosely in the panel. Most covers are cut out to tightly fit around the circumference of all the breakers and hold them in place.
Old 10-18-14, 08:26 AM
F
Ok, that might be why I noticed it then. The panel has a few slots snipped out, prolly why its not snug.
Thanks for explaining that.
Old 10-18-14, 08:30 AM
F
I checked the gauge of the wire into it and it's a #12.
My 20amp breaker has a #10 in it, as I checked it also.
The breaker in question(20amp w/#12 wire) has a microwave oven on it and a dishwasher on it. Plus two 20-amp GFCI twin outlets above the kitchen counter top ends. There is a coffee pot and a toaster that are plugged into those 20 amp outlets.
Thanks for the feedback.
Old 10-18-14, 08:37 AM
pcboss's Avatar
The countertop receptacle circuits should not feed the dishwasher. If the MW is over the range it should be on a dedicated circuit.
Old 10-18-14, 08:42 AM
You can get blanks if there are missing breaker knockouts in your panel cover. These blanks take the place and are the same size as a breaker. They also keep fingers out.
Old 10-18-14, 08:59 AM
F
Read more: http://www.doityourself.com/forum/el...#ixzz3GVqfrx3c
Fortunately that's not the case. The outlets above the counter have the coffee pot and the toaster on them.
My biggest concern is that #12 wire supporting 20 amps.
Old 10-18-14, 09:02 AM
F
I did just that. I had bought a couple for replacements and used the extra to fill those vacants. Thanks!
Old 10-18-14, 09:16 AM
pcboss's Avatar
Number 12 is the normal size for a 20 amp circuit.
Old 10-18-14, 09:28 AM
F
saweet! Thank goodness!
Saves me a lot of worry. And no need to touch anything there.
Thanks for the confirmation.
