Whirlpool Microwave Hood Combination Model YMH1141XM
Old 10-22-14, 07:00 AM
R
How do I change the fuse. The microwave fan and light work, though it blows when trying to heat food. Have reset the breaker several times.
Old 10-22-14, 05:53 PM
G
Received 2 Upvotes on 2 Posts
If I understand what you are saying, the breaker on your main electric panel kicks off when you turn on the microwave. That is not a fuse problem in the micro. There is a short somewhere which is tripping the breaker when you try to turn the micro on.
Old 10-22-14, 06:32 PM
ray2047's Avatar
Post moved to Electrical forum.
Old 10-22-14, 06:33 PM
ray2047's Avatar
Is it on a dedicated 20 amp circuit?
Old 10-22-14, 07:01 PM
Handyone's Avatar
If you swapped out a normal vent hood for a microwave combo, chances are the power supply is not capable of supporting new microwave.
I know Canada has different standards, but there's no way around this. The microwave requires a dedicated circuit, it uses a lot of power and the M/W Convection Combos use even more.
