Tap existing switch for remodel recess lights?
Old 10-23-14, 07:58 PM
We want to add recessed lights to our 2nd floor bedrooms. The rooms have 1 switch that controls the lower socket in 4 or so outlets. We want the switch to control the on/off of the recessed lights.
My question is, can I feed 14-2 romex from the attic to the switch and tap into the red "switch hot wire" as seen in the below picture?
Here's how the outlet looks.
Thanks!
Old 10-23-14, 08:16 PM
ray2047's Avatar
Not sure from picture. Are there two white wires connected only to each other in the switch box? Do you want the receptacles to be all hot all the time?
Old 10-23-14, 08:29 PM
Here's another look at the receptacle.
Yes, we want the top socket to be hot all the time. The switch will control the on/off of the lower socket and the recessed lights.
Old 10-23-14, 08:32 PM
ray2047's Avatar
Old 10-23-14, 08:41 PM
Received 3,980 Upvotes on 3,572 Posts
Do you only have 1) three wire cable in the switch box ?
Old 10-23-14, 08:55 PM
My bad, read your message wrong. There's only two wires connecting to the switch.
PJ - They're all separate wires right now...none of the 14-2 cable.
Old 10-23-14, 09:14 PM
As far as I can see you have 1) three wire cable. A cable contains multiple wires. Your cable contains a red, black and white wire.
You need to connect your new lighting circuit white neutral wire to the unused white.
I would remove the red wire from the switch. Then connect that red wire, your new black wire and a short piece of the same gauge black wire all together and cap with a wirenut. Now take your newly installed tail wire from your new splice and connect it to the switch,
Old 10-31-14, 05:43 PM
Thanks PJMax. I'll give it a shot and see how it goes.
