Installing a tandem breaker question
I plan on installing a tandem circuit breaker. I have installed breakers before. But my question with the tandem, is there a certain way it needs wired? I read on one site that you must make sure to alternate the phases and to make sure it is not on the same phase. Could anyone elaborate on what that means please. Thank you in advance.
Welcome to the forums! Since single phase residential only has one phase, we refer to them as "legs", or other terms. If you are referring to a double breaker (for a 240 volt circuit, or multiwire setup), it will automatically derive power from the two legs since the busses alternate going down the panel. If you are talking about a piggyback breaker, one behind the other, then it will be on the same leg.
I am referring to the piggy back breaker. Do you wire the ground a special way? Do you wire it any differently then a single pole breaker?
IIRC GE tandems can span both hots.
Ok, I see what you mean by piggyback design with the old Square D tandem. I really don't know why they changed their tandem design to have the switches side-by-side like they do today, must have been a cost reduction in there somewhere. Schneider Electric is noted for their cost reductions since the bought Square D.
