running wire to cooktop
Old 10-27-14, 04:42 PM
H
I have my wire run to the kitchen coming through the wall. it will enter a cabinet on the left side. there will be a junction box in the lower right of cabinet where the wire will be wire nutted to the armored cable from the cooktop above. So do I have to protect my 6-3 NM wire where it enters cabinet before it reaches junction box? below the cooktop are two drawers so I could see potential for wire getting hit with pots/pans if they are stuffed into the drawers. If I protect it-how?
Old 10-27-14, 04:49 PM
F
Received 39 Upvotes on 31 Posts
Sleeve it in a piece of conduit.
Old 10-27-14, 04:58 PM
H
Flex PVC like used in poll/spa OK? If putting it in conduit, leave jacket on? I thought the wires in conduit have to be THHN or THWN, and I don't know if the wires in my NM cable are rated as such. If you leave the sheath on and just adding protection, I guess wires don't have to be rated?
Old 10-27-14, 05:42 PM
ray2047's Avatar
It is common and good practice to sleeve cable for protection.
Old 10-27-14, 06:07 PM
pcboss's Avatar
Received 202 Upvotes on 176 Posts
A short piece of PVC conduit would work.
What are the electrical requirements for the cook top?
Old 10-27-14, 06:45 PM
H
I think I oversized it for future if ever need. I think it is 40 amp so I assume 8/3 would have been sufficient. I bought cable a long time ago and don't have the full install easily available. I found use instructions but not install instructions.
Old 10-27-14, 06:54 PM
Received 4,055 Upvotes on 3,638 Posts
It's always good to run larger than you need..... especially when it's almost impossible to replace it in the future.
