Stir plate wiring help
Old 10-27-14, 07:13 PM
I bought a switch at the Shack , and didn’t bother to ask hot to wire it. I want to install it on my stir plate for home brewing. Any tips? The power source is 12V 1.25A output going to the switch, then to a speed control (volume) knob, ten into an old computer fan. What sort of wire should i use?
Old 10-27-14, 07:19 PM
Received 3,416 Upvotes on 3,063 Posts
Looks like you could just cut the red wire and connect it to the switch. If it's too short you can use any small gauge wire..... #18, #20, #22 would be fine.
Doubling up on the switch will use both of the switching contacts in that switch for more reliability.
That switch is not lit..... is it ?
Old 10-27-14, 07:27 PM
So red wire from power to switch to knob? All else stays the same? How do I connect the red wire to all 4 terminals?
I don't recall of it is lighted or not. Will it matter?
Old 10-27-14, 07:33 PM
That switch just needs to open one leg of your circuit. I would double up the contacts like I've shown but you don't have to. You can just use one middle contact and one above or below it. I solder to the switches. If you don't have the ability to solder you could use two of those small crimp terminals in your picture.
If the switch is lit then the wiring pin designations change. That doesn't look like a lit switch as a lit switch usually would have five terminals instead of six.. I was just checking.
Old 10-27-14, 07:49 PM
Well, it must be a lit switch. With 6 terminals? The switch works if I wire it vertically instead of horizontally like you showed. And whichever end I connect it to, it operates when the switch is pushed to the opposite end - if that makes sense.
Old 10-27-14, 07:58 PM
No... a lit switch should have 5 terminals.... it looks like you have 6 there.
That is a double pole switch.... two sets of switching contacts.
If you push the switch to the red arrow direction... the red terminals are on.
The opposite for the blue arrow direction.
Old 10-27-14, 08:06 PM
Ah, I see. I misunderstood your first diagram. I wondered why it wouldn't light! Thanks for the help, and lesson in humility
Old 10-27-14, 08:50 PM
Absolutely no problem.
