Replacing ceiling fan wall switch
Old 11-02-14, 08:34 AM
T
I removed a ceiling fan/light wall switch that only had two wires coming out of it. The one I bought to replace has four: one AC in; one out to lights; one out to fan; and a ground. In the wall box, there is one hot; two black that I assume go to other outlets switches; three neutral; and a ground.
I've tried different combinations and haven't fixed it.
Suggestions?
Old 11-02-14, 08:56 AM
Received 3,897 Upvotes on 3,494 Posts
Welcome to the forums.
Some ceiling fans used a special control that would communicate multiple commands over two wires. If the switch you pulled out can control both fan and light.... then you need to replace it with a same brand/type switch.
Can you post any more info on the old switch.... like brand and model.
Old 11-02-14, 09:07 AM
T
Both switches are harbor Breeze - old one with two wires, new one with four.Name:  photo2.jpg
Old 11-02-14, 09:16 AM
T
Box and new switch
Old 11-02-14, 10:22 AM
pcboss's Avatar
Received 194 Upvotes on 170 Posts
The single black is probably the power into the box. The black and red in the same cable would typically go to the fan box. The new switch should have labels for the terminals.
Old 11-02-14, 10:27 AM
Your old controller is as I described it. It controls the fan by sending commands up to the fan on the hot wire. That is a two part system..... the control you removed and the receiver end in the fan.
In order to replace the switch like you'd like to do..... you may have to remove the remote control board in the fan and change the supply wiring.
Old 11-02-14, 10:46 AM
T
Do I need to incorporate the neutrals that are capped? I cannot remember if they were capped when I opened the box months ago.
Old 11-02-14, 10:51 AM
No... the neutrals remain as they are.
