grounded breaker popping
Old 11-02-14, 09:24 AM
P
I bought a used frig. it worked for a few days, now it keep popping the 20a breaker. If I disconnect the ground, it then works fine. I even trued a completely different circuit and again it pops in a few seconds, but if I disconnect the 3rd wire ground, it then works fine.
ideas?
tks,
pa
Old 11-02-14, 10:15 AM
ray2047's Avatar
The refrigerator has a short. It needs to be repaired or junked. It is unsafe to operate it in its present condition. Check the cord for signs of damage. Look inside the mechanical area for signs of frayed wiring. Unfortunately it may be a bad compressor and not worth fixing. It could also be mullion heaters shorted out. Try it on energy saver mode.
Old 11-02-14, 01:57 PM
CasualJoe's Avatar
Received 185 Upvotes on 166 Posts
Now you know why it was discarded or traded in on a new one. I'd try to see if whomever you bought it from will take it back.
Old 11-03-14, 08:34 AM
I
Received 45 Upvotes on 43 Posts
This could be something as simple as a cord or wire split open or rubbed bare on a sharp edge. Before completely junking it, I'd pop the back/bottom open and give the wiring a once-over to see if there's an obvious problem. If you don't find anything, then the compressor motor is probably junk.
Old 11-04-14, 01:11 PM
P
6.6 and 2.7 ohms from hot and neutral (or neutral and hot) wires to frig metal case.
pics:
[Link removed: Links to other forums not allowed] http://www.doityourself.com/forum/el...rt-images.html
Old 11-04-14, 01:22 PM
ray2047's Avatar
Sounds like a almost dead short.
