(15A?) receptacle off 30A dryer outlet?
Received 0 Votes
Hi, I'm in the process of installing an exterior GFCI receptacle in my garage, and have been looking for somewhere to run power from.
In my adventures, I found a nearby receptacle, that appears to run off a 30A dryer outlet. There's a junction box next to this outlet, that runs unprotected cable along the ceiling, through an adjacent storage room, and into the garage where it feeds this receptacle.
I was under the impression that dryer outlets were supposed to be a dedicated circuit?
I'm a novice, but am concerned that this existing receptacle is controlled by a 30A breaker, and probably shouldn't be wired into the dryer outlet circuit. I'm not sure that this is safe.
So, would it be a good idea to remove this receptacle, and the long section of unprotected cable, and restore the dryer to a dedicated circuit?
Thanks.
Ben.
Thanks.
Ben.
It is unsafe and should be removed immediately. A standard duplex 120 volt receptacle must be fused for no greater than 20 amps (or 15 amps if supplied by #14 cable). The method of running the cable may also be a non code compliant.
Post back and we can help you run power to the garage.
If you aren't using the dryer receptacle, remove it and replace the (hopefully) 2 pole breaker with two 15A singles and voila! 2 receptacle circuits at your disposal. The 10 AWG (again, hopefully) wire is fine to use for a 15A circuit.
But if it is a 3-wire dryer plug there may be no ground and the cable across the ceiling is still a problem.
In a perfect world it would be a unused 4-prong dryer plug and you could replace it with a subpanel.
Received 0 Votes
Thanks for the quick replies. I will remove the receptacle and unprotected wiring, and return the circuit to a dedicated 30A outlet.
Thanks for the help. Just to answer a couple of questions that came up:
* The dryer outlet has a four-prong cover. I will check the wiring inside. It's currently in use.
This is a 1956 house, so I doubt this is the only issue.
Edit: There's a 15A receptacle on another circuit in the garage. I'm considering drawing power from there, but need to work out what else is on the circuit. I figure, as someone had a second power source to the garage, it may already be maxed out. The GFCI is to power block heater on a pair of vehicles left outside in Canada's frigid winter.
Thanks again!
Ben.
Thanks again!
Ben.
