automatic dog feeder help pls
Received 0 Votes
guys need help.
I want to make automatic dog feeder, all i want is a circuit diagram.
What I want is somewhat like this.
I set time on alarm clock and as soon as alarm kicks in it should trigger a motor to unlock the door. So the challenge is to convert .4 v to 9 or 12 v. I need some what a relay or somethin. Pls help me with the circuit diagram.
Why mess around converting an alarm clock when you can buy a timer at any hardware or home center? Most of them come with at least two sets of clips so you could trigger it on and off twice each day if you wanted. Plug in a transformer of whatever voltage you need to run the gate or whatever you are going to use to dispense the food.
