3 switches to one switch.......want to get this right
Old 11-08-14, 01:55 PM
T
Hello,
I have three switches on three different walls. Each switch controls 2-3 ceiling lights. I have attached pics of the switches and lights. I wish to move the switches to a different wall. That wall already has a box installed and I purchased a switch with three rockers on it. I assume each side would have three screws so I could just connect the existing wires and be done. But one side has three and the other only has one. Thoughts on the best way to do thisName:  1.JPG
Old 11-08-14, 02:39 PM
ray2047's Avatar
Do all three lights share a common breaker? Are they switch loops? I see no neutrals at the switches. If they are switch loops the switch you have won't work.
Old 11-08-14, 03:17 PM
T
No, they are each on their own breaker. OK, so what looked like a good solution is not going to work. Is this possible to do or will I need to have a separate switch for each one.
Old 11-08-14, 07:42 PM
pcboss's Avatar
Received 181 Upvotes on 159 Posts
You will need three switches. The switch you have works for three objects on one circuit. The black feeds power to all three switches. Each brass screw is a switched hot.
Old 11-08-14, 08:35 PM
Mr.Awesome's Avatar
I'm assuming you are re-routing all 3 switch cables to one location.
You will need either a 3 gang box and f clips
http://www.ujr.ca/EN/4203200.jpg
Or go through the effort of installing a contactor controlled by a single switch.
Or possibly throw all the lights on one circuit.
Old 11-09-14, 07:40 AM
CasualJoe's Avatar
Received 179 Upvotes on 162 Posts
Not that it makes much difference to the solution, but these aren't NM cables, it must be a conduit system. I have never seen an insulated green stranded ground wire in NM cable nor have I seen orange conductors in NM cable. I would put all the lights on one circuit.
Old 11-09-14, 11:46 AM
Mr.Awesome's Avatar
Good catch joe, I didn't notice that.
If he has emt above a tiled ceiling, this might no be a bad project to swap some wires around.
