Splice Fabric sheathed wire to Romex?
Old 11-08-14, 01:24 PM
Is it okay to splice fabric sheathed wire to Romex? If so, is the size of the fabric sheathed cable marked anywhere? How do I determine what size Romex? What do I do with the ground wire?
Thanks!
Old 11-08-14, 01:32 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
You can not extend ungrounded cable because all new installations must meet current code which requires a ground. Based on your question and typical cloth NM the old cable does not contain a ground and can not be extended. You will need to run a new circuit from the breaker panel.
Old 11-08-14, 06:39 PM
pcboss's Avatar
Received 114 Votes on 99 Posts
The gauge of the wire can be obtained by using a pair of strippers.
If your circuit is grounded you would run the same size as the existing circuit and splice in an accessible junction box.
Old 11-08-14, 06:58 PM
A
Received 134 Votes on 123 Posts
Starting with an ungrounded fabric sheathed cable circuit and you decommissioned part of it from the breaker panel partway out, the orphaned rest of the circuit may be spliced onto the black and white of the new grounded Romex.
