Miswired 10-50R Dryer Outlet and Replacement
Old 11-09-14, 10:08 AM
V
Hey ya'll, new to the forum so hopefully I don't screw this up.
I am an electrical engineer but haven't designed a circuit in years and mostly small digital things at that. Working familiarity with NEC and electrician type work, but definitely a journeyman DIYer.
That said, Wifey and I just bought a new house, built in 1963 so some of the electrical is a bit dated. There was no washer/dryer when we moved in so we just bought one from Sears.
The dryer outlet is a 10-50R Outlet pictured below:
Name:  NEMA 10-50R Dryer Outlet.jpg
But the plug the installers put on the dryer is a 10-30P:
Name:  NEMA 10-30P Dryer Plug.jpg
And my breaker box has a 30 Amp circuit to the dryer (top left bar):
Name:  Breaker Box - 30A Dryer Circuit (Top).jpg
Here is where it gets dicey. I cut the power and pulled the receptacle. This is the (perceived) mess I found:
Name:  NEMA 10-50R Dryer Outlet Box.jpg
Tested it with my multimeter and confirmed I have expected values (240 from red to black, 120 from red/bare and black/bare, also 120 from red/white and black/white and 0 from bare/white). The bare ground wire was hooked directly up to the outlet while the white wire was just inserted in the box as you see, stripped with no wirenut or tape on it.
Awful current wiring setup aside, does this mean that I can just install a 14-30R outlet on the circuit? I can just return the 10-30P plug and get a 14-30P instead.
Thanks for your time.
Nate
Old 11-09-14, 10:15 AM
ray2047's Avatar
Yes, you are correct. Curious what size wire did they run? You might have to pigtail if that is #6.
Yes, but check the ground in the dryer is not connected to the neutral.
Old 11-09-14, 10:38 AM
V
Thanks for confirming ray. Always good to have a sanity check.
I'm not sure how to determine the wire size? Would I need to pull the wire further from the box to look at the sheathing?
The dryer is designed for either 10-30p or 14-30p per the instructions so it should be an easy swap.
Old 11-09-14, 10:41 AM
ray2047's Avatar
No need to determine actual size. If it fits the receptacle no problem. If it is too large you may have to pigtail on short lengths of #10 THHN/THWN wire.
Old 11-09-14, 11:49 AM
Mr.Awesome's Avatar
I think that is 10 AWG. I've never seen solid conductors larger than 10.
Old 11-09-14, 12:15 PM
V
ray: understood. It didn't feel like it was too thick to wrap. I'll take some pics of the final product and post them for closure.
Old 11-09-14, 12:21 PM
CasualJoe's Avatar
Received 185 Upvotes on 166 Posts
I've seen various colors of #8 solid copper TW, but it was a very long time ago.
