Wiring a switch
Old 11-09-14, 05:22 PM
N
Wiring a switch
Hi.
I'm trying to change a simple light switch, but I don't know how to wire it up. Currently, it is wired into a fitting three wires coming in one end (tan (T1) red (R1) and black (B1)) and two in the other end (tan (T2) and black (B2)). T1 is connected to T2. The R1 is connected to the top terminal of the switch and a black wire (B3) is connected to the bottom terminal of the switch, which is connected to B1 and B2. I'm trying to replace it with a switch with two black wires (b1 and b2) and a green (ground) wire (g1), but I'm not sure how to connect it.
My guess (based on some background research) is that the black wires in the wall (B1 and B2) are grounds, tan (T1 and T2) is common, and red (R1) is live. So should I connect b1 to R1, and connect b2 to g1, B1, and B2?
Thanks
Old 11-09-14, 05:35 PM
ray2047's Avatar
What is a "fitting"? Do you mean a switch box?
Do you mean three cables? A cable is two or more wires in a metallic or non metallic sheath.
Do you mean white red and black? Cables never have tan wires though if old enough aged white can sort of look tan.
Grounds are green or bare never black.
Do you mean neutral? Common would only apply to a 3-way switch circuit.
Old 11-09-14, 06:43 PM
N
Yeah.
No, three wires. There are two cables coming into the box, with the one (ostensibly) containing T1, B1 and R1, and the other T2 and B2.
I guess. It looks kind of tan. It's also pretty close to white.
Well, I don't have any green or bare wires, and I'm pretty sure there's a ground.
I guess so. I'm going off of terms I saw in places like this.
Do you happen to have any wiring suggestions based on the information I gave (which is all that I have)?
Old 11-09-14, 07:21 PM
ray2047's Avatar
Still a bit confused by your current wiring. In the diagram below where do the black and red of the 3-conductor cable go. Is the rest of the diagram correct?
Old 11-09-14, 07:32 PM
N
Looks pretty good. The black wires are connected, and both connect to the top terminal of the switch. The red wire connects to the bottom terminal (I think I mixed that up in my earlier description).
Old 11-09-14, 07:48 PM
ray2047's Avatar
Is this now correct?
Note: position of screws isn't relevant.
Old 11-09-14, 08:01 PM
N
Yep, that's it.
You mean upper or lower? I sort of figured as much, but I thought there was a chance it was relevant.
Old 11-09-14, 08:47 PM
ray2047's Avatar
Connect the two black wires to one of the black wires of the new switch and the red wire to the other black wire of the new switch. Coil the green wire up and leave disconnected.
With some switches such as 3-way switches the color of the screw does matter but never position because it can vary with the manufacturer. On a simple SPST switch such as you"re replacing which screw doesn't matter just the wires connected to it.
Old 11-09-14, 10:53 PM
N
The new switch says it won't work unless it's grounded. Should I not just connect the ground to the black wires? I.e., connect b1 to R1, and b2 and g1 to B1 and B2?
Old 11-09-14, 11:06 PM
Received 3,892 Upvotes on 3,489 Posts
You're saying new switch.... do you mean new electronic control... like a dimmer ?
Old 11-10-14, 12:21 AM
N
It's an occupancy-sensitive switch replacing a simple on/off switch.
Old 11-10-14, 08:53 AM
ray2047's Avatar
NO, Black is hot. Try it without a ground. If it doesn't work buy one that uses a neutral not a ground.
Old 11-10-14, 09:46 AM
N
Customer support recommended I try connecting the ground wire to the two white wires (so g1 to T1 and T2, b1 to B1 and B2, and b2 to R1). Can you verify that this is a good idea?
Old 11-10-14, 10:09 AM
ray2047's Avatar
I can verify it will work. I can't verify it is safe. I knew of that hack but couldn't say if it was safe so didn't mention it. I'd go with one that had a neutral unless there is no metal on the switch including the mounting yolk..
Old 11-10-14, 05:13 PM
N
In what way is it not safe? What might happen?
There is no exposed metal on the switch, apart from a few small screws that only attach plastic to plastic. Why is that important?
Old 11-10-14, 05:38 PM
ray2047's Avatar
Neutral carries current a ground should not. If you hook a neutral to ground there is a slight chance that under rare conditions if you touched metal on the switch while touching an earth ground you could get a shock. If though the switch is plastic then there is no metal to touch. The screws are isolated so should be okay. You should be safe connecting the ground to neutral.
