20 amp vs 30-40 amp Zinsco Breaker
Old 11-11-14, 03:54 PM
L
Received 1 Upvote on 1 Post
My question is whether I can use a 220v-20 amp Zinsco circuit breaker instead of having to purchase a 30-40 amp??
We own a 13yr. old Generac generator that is only use during power outages and I would like to install a 220 outlet closer to the breaker panel. The breakers are of the old Zinsco type and have become quite expensive and since I have an unused Zinsco 220v-20 amp could I use it rather than going out and purchase a 30-40 amp?
Not sure if it means anything; the generator has 3 receptacles with 3 circuit breakers: two 120v; 1 has a 20 amp breaker, and the other has a 30 amp breaker. The 3rd receptacle indicates its 120/220 volt and has a 20 amp breaker.
Suggestions/Comments appreciated.
Old 11-11-14, 04:21 PM
A
Received 5 Upvotes on 4 Posts
What's the outlet for? To backfeed? Don't even go there.
You need an inlet and a transfer switch/panel/interlock.
It sounds like your generator is only rated at 20 amps, 120/240. The 30 amp receptacle you see, is it a 120 only?
Old 11-11-14, 04:27 PM
ray2047's Avatar
If you mean a 240 volt receptacle you can't use a receptacle to connect a generator. You must use an inlet.
You can not connect a generator directly to a breaker panel without using an interlock or a transfer switch.
Someone will I'm also sure remind you in general Zinsco panels are considered risky to use but that is for another thread. http://inspectapedia.com/electric/Zinsco.htm
Old 11-11-14, 05:06 PM
L
Sounds from comments the generator is rated at 20 amp so the Zinsco breaker will work. Thanks to all for the input!!.
Old 11-11-14, 05:33 PM
ray2047's Avatar
No the reply was it is unsafe to connect a generator using a receptacle. No the reply was it is unsafe not to use a transfer switch or an interlock which probably doesn't exist for a Zinsco panel.
Old 11-11-14, 05:50 PM
L
Exactly, "interlock probably does not exist for a Zinsco panel". Considering other options??
Old 11-11-14, 06:02 PM
ray2047's Avatar
Transfer switch or transfer panel. Since it is only 20 amps a transfer panel is probably best.
Old 11-11-14, 06:24 PM
L
That's what I was thinking, not familiar how the transfer switch or panel functions so I need to do some studying to determine what is required to install either option and the least labor intensive alternative yet be safe. Again, thanks to all for the input.
Old 11-11-14, 07:31 PM
ray2047's Avatar
I'd suggest a plan B. Install a separately derived set of two duplex receptacles in the house run to an inlet outside. You could use a multiwire circuit off the 120/240 generator receptacle to provide two 20 amp 120 circuits. Then you could just run extension cords in the house to wherever you need power.
If your interested I can give you details.
Old 11-12-14, 09:29 AM
CasualJoe's Avatar
Received 185 Upvotes on 166 Posts
I wouldn't spend anything on that project without getting rid of the Zinsco fire hazard. I would replace the Zinsco with a new modern circuit breaker panel and an interlock cover, if the local AHJ will approve an interlock cover.
