troubleshoot new porch light
Old 11-11-14, 09:04 PM
R
Question troubleshoot new porch light
power source to fixture 12/2 wire, then in conduit they ran 12/2 from switch to fixture. I took old light down thinking I would just hook it right back up like they had it (wrong). my porch light switch shares a box with three other switches that operate three other things. when I hook it up the switches do different things....so I left porch light unhooked and hooked black to black white to white and the other three switches work. and help would be awesome. If I hook light to power source wires without switch wires,,the breaker run the light
Old 11-11-14, 09:29 PM
pcboss's Avatar
Received 194 Upvotes on 170 Posts
The new light should have connected to the same wires as the old. Any other splices should have been left alone.
The fixture connects to the switched hot, not the constant hot.
Old 11-11-14, 10:07 PM
R
I just did that to test the light. the wires just came undone, like the wire nuts were not put on tight. they did not mark white wire.. I tried black from power source to white switch. white from power to white on light. black to black on switch...no go..and tied reversing them ..no go...
Old 11-11-14, 10:21 PM
Received 3,897 Upvotes on 3,494 Posts
I'm lost here.....
You have power to the light junction box and then a two wire cable down to the switch. The quantity of the switches should have no bearing as only one switch should be connected. If that is a two wire switch lead like you've said.... and it affects the other switches then you have problems.
Like the boss mentioned.... the new light should have just connected to the same black and white wires as the old light.
In the diagram is a switch loop circuit.
Old 11-11-14, 10:38 PM
R
Yes Sir,, that's what I tried first. and it makes the other switches dim other lights and some times two switches have to be up to make porch light come on, then light on garage dim lol....
Old 11-11-14, 11:06 PM
ray2047's Avatar
At the switch there should only be the black and white of a single cable connected to the switch. There should be absolutely no other wires connected to the switch. Can you post a picture of the switch? http://www.doityourself.com/forum/li...rt-images.html
Old 11-23-14, 09:42 AM
R
no white wire on switches
Name:  switchesand lights.jpg
Size:  33.5 KB!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old 11-23-14, 09:46 AM
chandler's Avatar
Received 9 Upvotes on 8 Posts
Aaiiiee. Pull all that tape off the switches and the bcaps. Not needed. That way we can see what goes where. Also we need to see the other wires in the box, so a lower shot may help without having to pull the wires out.
R
black and white are the power source
Name:  power source blackand white.jpg
Size:  19.1 KB the little black one are light,,,,the grey and white splice into black and white, back to the switch
so there will be no grey at switch
Old 11-23-14, 09:49 AM
R
Name:  switch box 2.jpg
Size:  35.7 KB the caped off in yellow have power,,must be from something old
Last edited by rocks4ever; 11-23-14 at 09:58 AM. Reason: found another picture that might help
Old 11-23-14, 10:06 AM
R
I will take a better shot without tape and the blue cap
Old 11-23-14, 10:33 AM
Which switch is for the light in question..... 1,2,3,4 ?
Is my labeling of the wiring correct below ?
Old 12-02-14, 10:11 PM
R
the second switch I do believe
Old 12-02-14, 11:05 PM
R
yes labeling is correct I believe second switch
