Terminating a romex line in the attic
Old 11-12-14, 07:27 PM
Received 7 Upvotes on 6 Posts
While roaming around in the attic trying to figure out which circuit goes where...I found a 12-2 romex wire that goes no where.
Just a run of romex coming from somewhere far away, the hot and neutral capped with wire nuts, and just sitting below blown insulation. I know which circuit it is from.
At this moment I do not want to trace it to the other end to get rid of it yet. What is the best way to terminate it? I don't think it's a good idea to leave it the way it is.
Do I just get a box with a blank cover, connect the wire to it, and screw the box somewhere on the rafters or joist?
Old 11-12-14, 07:39 PM
pcboss's Avatar
Received 194 Upvotes on 170 Posts
That plan sounds good. Be sure to mark the location of the box if under the insulation.
I would label the cover with the circuit number for later.
Old 11-13-14, 12:27 AM
F
I would mount the box above the level of the insulation. If you have truss construction and need to mount the box on a piece of material fastened to the truss, be sure to fasten to only one chord of the truss and let the other end float.
Old 11-13-14, 03:51 PM
Mr.Awesome's Avatar
Sounds like you have a feed for an attic light.
