wire question
Old 11-13-14, 10:43 AM
D
wire question
changing out a light fixture in kitchen.
black and white are showing hot on the volt tester when switch is on, not hot when off.
there is only black/white/ground in ceiling.
is it possible i do not have a neutral wire or is something else possibly the problem?
Old 11-13-14, 10:45 AM
Received 1,190 Upvotes on 1,147 Posts
What do you see at the switch and how are you measuring 'hot' in the ceiling?
Old 11-13-14, 10:47 AM
D
switch shows black/white/ground
i have a home depot voltage meter, beeps when wire is hot.
Old 11-13-14, 11:10 AM
Your tester isn't worth anything, can you get an actual multimeter? Cheap analog one (
Old 11-13-14, 11:36 AM
D
i'll have to find a multimeter
not sure how it is hooked up. don't know too much about this stuff
Old 11-13-14, 12:58 PM
Can you pull the switch out of the box and take a picture or two?
Old 11-13-14, 06:19 PM
D
the wires are so short it won't budge
Old 11-13-14, 06:20 PM
CasualJoe's Avatar
Received 173 Upvotes on 156 Posts
A non-contact tester is not reliable when troubleshooting or analyzing a condition. The white is probably your neutral. I assume the old fixture worked, right?
Old 11-17-14, 06:36 PM
D
there was no fixture in the ceiling originally. more than likely to hide something wrong with the wiring during inspections.
Old 11-17-14, 06:42 PM
pcboss's Avatar
Received 163 Upvotes on 142 Posts
If all you have is a black,a white and a ground for the fixture the connections are just color to color.
Old 11-18-14, 08:45 AM
D
i did the black/black white/white/ ground/ground
nothing at all happens.
Old 11-18-14, 08:56 AM
ray2047's Avatar
We need to see the wires at the switch.
Pull it as far as it will go and take a picture. http://www.doityourself.com/forum/li...rt-images.html You may end up having to cut the wires to get it out but lets wait for the pictures. We may see a better way.
