Intersystem Bonding Terminal Question
I am located in MI and on the 2008 NEC.
Is it permissible to connect an intersystem bonding terminal to the neutral bar of the service panel using a separate conductor instead of the GEC?
The way the requirement is written I don't think so, but would need to read the exact words. Why would you consider this?
The wall the Meter base and panel are located on has a stepped out foundation. For neatness I ran the GEC in PVC with an offset. There is not enough room to add the IBT into the run before the offset.
I don't have a copy of the 2008 NEC on hand but I believe 250.94 applies. I want to say it allows me to.
Arlington | Intersystem Grounding Bridges with PVC Adapter
I generally put them around 1 - 2 feet above grade, depending on what seems to make sense with that particular house. I'd say anywhere above grade should be OK, just needs to be accessible.
