Can a outdoor panel connect to indoor circuits
Old 11-16-14, 03:38 PM
Electrician replaced my old FPE outdoor shutoff with a new Siemens panel that also provides some breakers (8/16) - this panel provides feeds to my indoor panel - just like the old FPE shutoff did.
Searched for this, but couldn't detect it.
Can this new outdoor panel feed to indoor circuit in order to free up a couple slots on the indoor panel? Running Sched 80 pvc pipe underground to connect point.
Thanks,
Jimmy
Old 11-16-14, 03:51 PM
ray2047's Avatar
Done all the time here. The main panels are often outside below the meter. I doubt you need to use schedule 80. Schedule 40 should be okay unless it is in an area likely to to receive more then normal abuse.
Old 11-16-14, 03:55 PM
F
Most likely the answer is yes, need a few more details to be absolutely certain.
Old 11-16-14, 06:05 PM
Thanks. Electrician said it was ok, but we were not going to permit it so wanted to double check if ok. May still go verify with city.
Sched 80 - just makes me feel better about it.
PS, new panel/shutoff is right next to meter.
Jimmy
Old 11-17-14, 06:52 AM
I
Received 45 Upvotes on 43 Posts
Whenever you run from inside to outside make sure the conduits are well sealed on both sides with duct seal putty to prevent condensation from getting into the boxes.
