lights dim occasionally
Old 11-19-14, 06:24 AM
Q
Received 1 Upvote on 1 Post
The lights in the house dim occasionally.
I've noticed this when I have a slow combustion burner fan on and it changes speed. I am not sure if the fan is changing speed or the dimming causes it to change speed.
They are both on 15A circuits but different circuits.
Is this normal?
Old 11-20-14, 07:16 AM
Q
Should this only happen if they are on the same circuit?
Old 11-20-14, 10:12 AM
Z
Received 422 Upvotes on 375 Posts
Most people notice lights dimming momentarily when large motor loads are started up. Usually this means the A/C, clothes dryer or vacuum cleaner. This is quite normal and has to do with the large startup load for the larger motors.
I find it a bit odd that it's happening with a smaller motor, but it's quite possible it can be caused by that. Are both these circuits on a subpanel? Or do you only have one main panel in your house?
Old 11-20-14, 10:34 AM
Q
One main panel...(actually there's a distribution panel but these lights and receptacle are not on the circuits in that panel).
It's not on start up but whilst it's actually running.
The lights are on a dimmer.
I can't tell if the motor is changing speed momentarily or if the dimmer is mybe fluctuating the light but I hear the motor change speed and the lights dim at the same time.
Old 11-20-14, 02:57 PM
chandler's Avatar
Received 9 Upvotes on 8 Posts
It may not have anything to do with the motor you are questioning. It can happen with your refrigerator turning on using a completely different circuit. It can happen with your house heat, or, as Zorfdt indicated many other applications.
