Need a receptacle that will support three 240v appliances
Old 11-19-14, 09:06 AM
I need to be able to plug in 3 appliances that are 240v and 400w
I currently have a 250v 4 prong receptacle that an old hot tub pump plugged into.
My panel is 100 amp
I am unsure of how to proceed. I can provide any additional information or pictures.
Thanks for looking.
Old 11-19-14, 09:14 AM
pcboss's Avatar
Received 196 Upvotes on 172 Posts
Not sure of your location.
Most 240 devices are dedicated circuits.
Old 11-19-14, 09:20 AM
ray2047's Avatar
What are the three appliances? Do you mean swapped out one at a time or all three plugged in and working at the same time?
Old 11-19-14, 09:39 AM
I am in Michigan
Can I convert that 250v receptacle to 240v?
Old 11-19-14, 09:46 AM
pcboss's Avatar
There is no need. Devices are rated at 125 and 250 even though the US voltages are 120/240.
Old 11-19-14, 09:55 AM
They are electronic ballasts for HID bulbs
All 3 would need to be on at the same time
The 240v plug does not fit the 250v receptacle that is there now.
Old 11-19-14, 10:02 AM
pcboss's Avatar
What plug and receptacle configurations are there now?
Old 11-19-14, 10:42 AM
This is the current plug 250v 50amps
[ATTACH=CONFIG]42014[/ATTACH]
and the plug on the cord looks like this (the 240v pictured on the right)
[ATTACH=CONFIG]42015[/ATTACH]
Old 11-19-14, 10:51 AM
pcboss's Avatar
Along with adding three receptacles and the wiring you are going to need to change the breaker to a two pole 15 or 20 amp breaker. You are probably going to need to pigtail smaller wires to each end to fit the breaker and receptacle.
Old 11-19-14, 11:57 AM
Geochurchi's Avatar
Received 161 Upvotes on 147 Posts
How many conductors are in the cable that feeds that 50 amp rec?
You
Old 11-19-14, 03:12 PM
I'm sorry but I don't understand the question of how many conductors??
The 250v receptacle is the only one on the circuit that I can tell. It was what an old hot-tun pump was plugged into.
pcboss: Thanks for your response
Old 11-19-14, 03:30 PM
pcboss's Avatar
Based on the receptacle I would say you have two hots and a ground.
Old 11-21-14, 09:13 AM
P
Convert the cable that supplies the 50 amp receptacle from a "Branch Circuit" to a "Feeder". This is effected by having the conductors of the 50 cable terminate on the lugs of a "Main Lugs" panel that can accommodate three 2-pole breakers.
From the panel, you will have three "Branch Circuits" , each supplying a receptacle. The "rating" of the individual Branch Circuit CB's, the Branch Circuit conductors, and the receptacles, depends upon the load in amperes on each individual Branch Circuit.
A "Branch Circuit" is the conductors protected by the "last" overcurrent protective device in a wiring system, in this case the CB's protecting the conductors that terminate on receptacles.
Old 11-21-14, 09:49 AM
Geochurchi's Avatar
I was hoping it might be a 3wire with ground in which case you could convert the 50 amp receptacle into a sub panel and bring your 3 new receptacles out of it.
Just a thought
Geo
Old 11-21-14, 01:50 PM
CasualJoe's Avatar
Received 185 Upvotes on 166 Posts
I see no need for a subpanel or 3 dedicated circuits. I'd just feed the 3 receptacles with the existing branch circuit after the circuit breaker was changed to a 15 or 20 amp.
Old 11-21-14, 01:52 PM
I
Received 45 Upvotes on 43 Posts
Agreed. This easily falls into the realm of a 20A 240V circuit with a few 6-20 receptacles.
