Garage heater install
Installing a 5000w 240v heater. Maybe 6 feet away from the main electrical panel that is drywalled in. Was planning on running conduit so I don't have to try and fish through the wall insulation up into the attic. Pulling a permit
How do I get out from the side/top of the box and get out of the drywall to mount the conduit? Do I have to use EMT or can I flex the whole way? Either way, plastic or metal?
30 amp breaker and 10 gauge wire? Romex or THHN? Does the ground need to be 10 gauge? Romex would be cheaper but is that ok ? How big of conduit?
Is your main electrical panel's face flush with the wall and the box finished off behind the sheetrock or is your panel box mounted on the face of the sheetrock so you have access to the sides?
The face of the electrical panel is mounted flush with the drywall. I can't access the sides without cutting out drywall(which I figured I would have to some of to get the conduit in)
The insulation in the wall is a loose fill
Can't find a short metallic whip though, think that would be the cheapest option if I can find it instead of buying 25' of MC and connectors
Edit: Actually, can I even use MC instead of FMC? I was just thinking MC so I didn't have to buy the FMC and all the individual color wires probably all in 25' minimums
If there is more than one place to plug into you can install a 20 amp breaker with 15 amp receptacles. Garage receptacles require gfi protection.
