Reload this Page >
#6 stranded conductor doesn't fit into the hole in the neutral bar?
Old 11-22-14, 07:57 AM
Received 2 Upvotes on 2 Posts
While trying to add a new circuit I noticed the white neutral conductor which is a #6 stranded was not fully inserted into the hole in the neutral bar. About half was in the hole and the other half "pulled back".
Is this typical? I released the screw and pulled it out, cut it shorter a bit stripped the insulation, and I had a hard time pushing it into the hole as well. Is it supposed to fit? Are standard neutral bar holes big enough for the bigger conductors?
Old 11-22-14, 08:11 AM
chandler's Avatar
Received 9 Upvotes on 8 Posts
Best way is to add a neutral bar adapter for your larger wire. GE PowerMark Gold Neutral/Ground Kit-TLK20CP at The Home Depot
Old 11-22-14, 12:24 PM
pcboss's Avatar
Received 163 Upvotes on 142 Posts
Some bars have different size holes. The label should tell. Many bars accept a #4 or smaller without an adapter.
Old 11-22-14, 12:38 PM
ray2047's Avatar
If you have a branch circuit ground wire in one of the large neutral bar holes you might want to move it if it will fit a smaller hole or add a ground bar. However Larry's suggestion may be easiest.
Old 11-22-14, 07:01 PM
CasualJoe's Avatar
Received 173 Upvotes on 156 Posts
There is more than one style depending on the manufacturer. Here is the type adapter I like.
Square D QO 70 Amp Auxiliary Neutral Lug Kit-QO70ANCP at The Home Depot
But......a #6 should fit any neutral bus without using an adapter.
Old 11-25-14, 07:23 PM
If you look closely, the neutral bar should have the gauge ranges stamped on side...6-14 is typical for branch neutral bar. A lug kit for neutral bar will work as suggested by others...
Old 11-25-14, 11:04 PM
Justin Smith's Avatar
Received 1 Upvote on 1 Post
If I am not mistaken, the older (early-mid 1990s and before) GE panels had neutral bars that only took up to a #8 or #10 except for a few holes.
Old 11-26-14, 03:56 AM
W
I can tell you a Red Neck way to do this , but I would get yelled at . :-(
What does the # 6 neutral go to ?
God bless
Wyr
