Help ! voltage is only 0.3 v from receptacle
Old 11-25-14, 07:43 PM
Recently I renovated my kitchen. When I tested a hot & neutral wires using a digital multimeter in the kitchen, the voltage is only 0.3v. Then I connected a receptacle to that hot & neutral wires, tested again, still got 0.3v from the receptacle holes.
I tried to use that receptacle to power up a table lamps, and it works fine. I know this receptacle worked before the renovation, it used to provide power for a refrigerator.
The multimeter is in good condition and I tested already.
Is there anything I should worry about ? or just leave it like that?
Thanks for any advice...
Old 11-25-14, 08:58 PM
What are you reading when you touch the white and black wire? Should be 110 volts.
Tried plugging something in that uses more power like a drill?
Tried a different outlet in a different room to test the meter?
Mod Note: No, not 110 volts. It should be about 120 volts.
Old 11-25-14, 09:35 PM
pcboss's Avatar
Received 40 Votes on 35 Posts
A poor or marginal connection can influence the voltage readings.
Old 11-25-14, 09:48 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
Sometimes the probe just won't pick up a reading from the slots. If it is a digital multimeter the 0.3v is probably just induced voltage.
Old 11-25-14, 10:31 PM
Received 515 Votes on 485 Posts
Are you certain the meter is in AC mode and not DC mode ?
If yes.... put meter into OHMS mode and touch the two leads together. Your meter should register the short.... if not you have a defective probe or a blown meter protection fuse.
Old 11-26-14, 04:45 PM
It's my fault. One of the test lead wasn't pushed into the tester completely. I think that's why sometimes it get wrong readings.
Thanks for everybody's help !!!
