Dc power adapter cable through wall then out by outlet?
Old 11-30-14, 11:05 AM
I have a couple questions and maybe could get a couple suggestions on if anything better can be done easily.
I am looking to install a few WiFi security cameras and they run off of a DC power adapter.
According to standard electrical code can low voltage DC power adapter (wire only) be ran inside a wall? I know local codes will vary.
I was thinking of running the wire down inside the wall and come out near the AC outlet so I can plug in the power adapter.
Do they make outlet covers with a 1/4-5/16 round hole at a corner or anyway to make a neat looking installation?
Any help will be greatly appreciated.
Thanks
Old 11-30-14, 11:07 AM
pcboss's Avatar
Received 163 Upvotes on 142 Posts
The wiring from the wall wart is most likely not rated for in wall use.
