Wiring 20 amp 4800 watt 240 volt heater
Old 12-04-14, 07:03 AM
R
Am trying to get heat into new basement in house under construction in Northern Ontario.
Panel is in and inspected. Heater I have has 3 wires i.e. black white green. Looks like plug end was cut off.
I sense NMD 12/2 should be used connected to 20 amp breaker. Likely have to run 50ft of wire. Is there a benefit to using higher gauge wire i.e. 10/2.
Thanks for thoughts, confirmations or corrections.
Old 12-04-14, 07:10 AM
Gunguy45's Avatar
Super Moderator
Received 6 Upvotes on 6 Posts
If the heater was originally a plug in, then that's how it should be used.
Is this just for temporary heat? If so than an outlet should be wired and the cord replaced on the heater. A heavy gauge ext cord can be used if temporary.
You can't run a 20A (4800/240) heater on a 20A circuit since that is a continuous load. At least I don't think so. IIRC 80% of circuit capacity is the standard.
Old 12-04-14, 08:24 AM
Received 3,750 Upvotes on 3,362 Posts
Vic is right.... you definitely need to run #10 and use a 2P30amp circuit breaker for the heater.
Old 12-04-14, 07:56 PM
R
the heaters are temporary until basement cemented, furnace in, etc. Appears fron your advice 30 amp breaker should be used. Would that be with 10/2 wire i.e.black, white with copper ground?
Thanks
Old 12-04-14, 08:06 PM
Gunguy45's Avatar
Super Moderator
CAN is a little different in their wiring colors I think. I'd just put in a temp outlet near the panel with proper receptacle and run a heavy duty ext cord. You said heater before...but then you just said heaters (plural)?
It's a new construction correct? I'd ask your electrician or GC for local advice.
Old 12-04-14, 08:18 PM
R
Sorry Vic. I have 2 of these heaters so will need 2 circuits. Yes it is new construction and I need to get temporary heat in basement until furnace is installed, etc.
Old 12-04-14, 08:35 PM
Gunguy45's Avatar
Super Moderator
Even more so...have the sparky give you some temp outlets where you need them or use a really heavy duty ext cord from a central box area.
Old 12-04-14, 10:02 PM
Mr.Awesome's Avatar
Receptacles beside your panel isnt a bad idea. Even after your house is done its handy to have somewhere to plug in to beside the panel.
If youre gung ho about not adding extra receptacles, just run the cords right in to the panel on two 30a 2pole breakers for now. One of those breakers will likely get used for your dryer anyways.
