fuse to breaker
Old 12-05-14, 11:51 AM
D
fuse to breaker
Has anyone used jumper wires to connect an older fuse box to a newer small breaker panel
????any links to pics and info???
Old 12-05-14, 11:54 AM
Received 3,988 Upvotes on 3,580 Posts
"jumper wires"
It's more than jumper wires. You need to have two fuses in that old fuse box to supply power to the new sub panel. The wire needs to be sized based on the sub panel and the fuses size.
You also need a neutral and a ground wire to your new sub panel.
Old 12-05-14, 02:57 PM
pcboss's Avatar
Received 196 Upvotes on 172 Posts
I doubt that this is done much. Normally a larger panel is installed so everything is on a breaker and not split between breakers and fuses.
Old 12-05-14, 06:55 PM
CasualJoe's Avatar
Received 185 Upvotes on 166 Posts
If you still have fuses, the service is at least 50 years old and probably needs to be entirely replaced.
