Dimmer switch with no ground connection
Old 12-07-14, 04:28 PM
artieess's Avatar
I have an older dimmer switch that I'm hoping to use as a temperature control for a solderi g iron (like this: $10ish DIY Variable Temp Soldering Iron Controller)
The dimmer does not have a ground wire or ground screw. So my questionsmare (1) do I need to ground the switch; and (2) if so, how do I do that? Thanks
Last edited by ray2047; 12-07-14 at 04:49 PM. Reason: Add image to clarify question.
Old 12-07-14, 04:44 PM
ray2047's Avatar
Connect the ground to the the box and receptacle. The dimmer may be mostly plastic which is why there is no ground.
Old 12-07-14, 07:07 PM
CasualJoe's Avatar
Received 185 Upvotes on 166 Posts
Exactly! Devices mounted to a raised 1900 device cover do not need a hardwired ground wire.
Old 12-09-14, 03:19 AM
artieess's Avatar
thank you
Thanks. I did as Ray advised and everything works just fine. Appreciate the help.
