Ser cable
Old 12-08-14, 09:37 AM
P
Ser cable
Looking for about 30 feet of SER cable for a 100A subpanel. Looked at our local Lowe's and it was $1.49 per foot for 2-2-2-4 Aluminum and $7.49 per foot for 2-2-2-4 Copper (I think Home Depot ws the same) ...Does that sound about right on prices? I want to do the subpanel correct but that is a big difference in price, is there any benefit on getting the copper?
Copper:
http://www.lowes.com/ProductDisplay?...ductId=4284355
Aluminum:
http://www.lowes.com/ProductDisplay?...ductId=4294349
Old 12-08-14, 01:03 PM
pcboss's Avatar
Received 194 Upvotes on 170 Posts
The ampacity of copper is higher than the same size in aluminum.
Old 12-08-14, 01:24 PM
P
I didn't even see that.. The copper is rated for 130A and the Aluminum is rated for 100A... I guess I'll go with Aluminum since my subpanel will only be 100A. Thanks
Old 12-08-14, 01:53 PM
I
Received 45 Upvotes on 43 Posts
Copper is somewhat less susceptible to corrosion problems, although generally not a big issue for electrical equipment installed in an appropriate weatherproof fashion. Aluminum should be terminated with an anti-oxidation compound whereas copper does not require that step.
Old 12-18-14, 01:10 PM
P
The copper SER is special order and takes weeks so have to get something else. I went to Home Depot and one of their employees showed me a 2/3 NMB copper cable (three #2 conductors and a ground) and said all contractors are using that to feed 100 amp panels but I thought i was rated for only 95 Amps. Can I use this cable?
They also have #2 THHN individual copper wire but not sure on the amp rating on those.
Thanks
Old 12-18-14, 01:26 PM
I
Yes copper #2/3g NM can be used to feed a 100A panel as long as the run is entirely indoors and protected from damage. The 95A ampacity can be rounded up to the next standard breaker size of 100A.
Old 12-18-14, 01:50 PM
P
Sweet!!...The cable will going up through the attic (joist) (about 20 feet across) and then back down to the supanel on the other wall in the laundry room, so indoors. Would there be need to put it in conduit, if so, what size (2")?
Old 12-18-14, 01:56 PM
I
The cable does not require any conduit. For protection, it should be secured to "substantial framing members" such as 2x4s where possible. If the cable runs within 7' of the attic access door, or if the attic has permanent stairs, the cable must run the complete length along a 2x4 for protection from getting stepped on.
Old 12-18-14, 02:04 PM
P
it will be attached to a 2x6 Attic Joist that runs the span of the room.. Thanks again!!
