Lights work outlets don't
Old 12-08-14, 04:01 PM
The other night we had too many things going on one circuit.
All the outlets died but the lights did not.
The breaker wasn't tripped.
The GFI won't reset.
I replaced the GFI but nothing changed.
Do I need to replace the other 3 outlets too?
Thank you... any help is much appreciated.
Old 12-08-14, 04:12 PM
chandler's Avatar
Received 10 Upvotes on 9 Posts
Welcome to the forums! Lights and receptacle circuits are usually separate. Sometimes breakers "look" as if they are not tripped. Turn the breaker completely off then back on. We can go further once you do that.
Old 12-08-14, 04:45 PM
pcboss's Avatar
Received 205 Upvotes on 179 Posts
Try to go through these steps. I suspect a loose or failed connection from the high current draw.
http://www.doityourself.com/forum/el...ther-info.html
