Outlet issues
Outlet issues
All my kitchen outlets do not work, my cheap meter says there is 118 V but nothing plugged in works. Any ideas? Checked the breaker box and it shows the same volts leaving the breaker. Could this be a ground issue?
Welcome to the forums! What type instrument are you measuring voltage with? An analog meter is best for DIY work. About $10 at the box stores. I doubt it is a grounding problem, but it could be a neutral problem. Are you measuring at a GFCI receptacle? What are you measuring between? Hot and neutral or hot and ground?
Yes, you should be checking hot-to-neutral (the two blades, not the ground). Are you checking both top and bottom of your kitchen plugs? Kitchen circuits are supposed to be separated - top and bottom should be on two different circuits. If both are out, you likely have a missing neutral.
Edit: you should also read around 240V if you measure between the two hot spades.
Matt..... I believe the split receptacle method is code in Canada but is not usually used here in the States.
Measuring ground to hot, no GFI. Would checking between the hot and neutral indicate if there is a problem?
