110 conversion
Old 12-18-14, 06:34 PM
110 conversion
I have a blower that I want to use on my motorcycle. The blower runs on 110 and my motorcycle uses a 12v battery. What would be the best way to convert this, and is there any kind of device i can hook up to sync the air flow with my throttle or a device I can mount on my bike to turn the air flow up and down easier?
Old 12-18-14, 06:44 PM
Gunguy45's Avatar
Super Moderator
Received 6 Upvotes on 6 Posts
I have no clue what you mean by a "blower", but M/C electrical systems are barely adequate to run the bike in most cases. Trying to run a 120V (not 110) off a bike charging system is going to cause major problems.
Maybe if you explain in a bit more detail what you are trying to achieve (end result), someone can help.
Old 12-19-14, 06:05 AM
chandler's Avatar
Received 9 Upvotes on 8 Posts
Aaahh, my morning wake up Will this be a blower for snow, leaves, or do you want to use it as a fuel induction modification for the motor cycle? As Vic said, the electrical system, even with an inverter won't be adequate.
Old 12-19-14, 07:42 AM
I
Received 45 Upvotes on 43 Posts
Now that I've got to see.
