Kitchen exhaust fan install
I am trying to install a exhaust fan in the kitchen, but I am having a little trouble with the wiring. They wires coming out the the wall and hood are only blk and white. Per the instructions manual, I am supposed to ground the wire to the green screw, but there is no wire to ground. What do I do? Isn't it dangerous if I don't ground the wire? Help would be much appreciated!
You could run a new cable with ground from the breaker box but that is not needed for it to work.
Above assumes original wiring is non metallic cable.
Perhaps a picture would help.
I don't know if these pictures will show, as I posted them through my phone. But there are two wires coming out from the walls, a black and white one. The inside of the wire looks like it's made of copper I think, but the wire itself is wrapped in some type of plastic.
Pictures tell a thousand words.
You have a metal clad cable there with copper wires. Technically that is your ground.
That connector should fit right into a knockout on the exhaust fan. Tighten the locknut up snugly on the inside.
