New 200 amp service underground
Old 12-23-14, 03:58 PM
R
I am new to the forums so I apologize in advance if I am doing this incorrectly.
I need to take 200 amp service from a meter box/pole underground for a distance of 250-300 ft. Our county bases their regulations on the NEC 2008 guidelines.
From the meter box 300 ft in distance to the house (wet environment), what type of conductor(s)/conduit combination should I go with?
For example, can I get by with using 2 inch or smaller schedule 40 PVC conduit or do I have to go with 3 inch? I am looking for something relatively inexpensive, without too much loss.
Thank you :-)
Old 12-23-14, 05:36 PM
pcboss's Avatar
Received 194 Upvotes on 170 Posts
URD direct buried would be one option. If you've ground is rocky I would advise conduit with XHWN conductors.
Old 12-24-14, 08:29 AM
CasualJoe's Avatar
Received 185 Upvotes on 166 Posts
Is there a 200 amp circuit breaker or fusible switch at the meter on the pole?
