Wiring multiple baseboard heaters.
Old 12-27-14, 05:25 PM
B
Had some renos done in three rooms that were wired in sequence. all the heaters and thermostats were removed but the wires all remain, each room has its own thermostat. Anyways hooked the first one up to the themostat and to the baseboard. I used a double pole thermostat. The heater will not put off any heat. I checked when the thermostat is off it kills the power to the basebaord. I tryed a second heater still it does not work. could it have anything to do with the wired down the run not being hooked up
Old 12-27-14, 06:12 PM
Received 3,891 Upvotes on 3,488 Posts
If you used a double pole thermostat then you should have your feed in and feed out in the thermostat box. If that is correct it should be fairly easy to measure and see where the power is getting lost.
The circuit should work with only one heater connected. We can't tell you exactly why it's not working unless you can tell us EXACTLY how the wiring is run.
Old 12-27-14, 06:26 PM
pcboss's Avatar
Received 194 Upvotes on 170 Posts
If the old heaters were daisy chained the upstream heater will need to be on for the other heaters to have power. Do you know how the wires are run?
Old 12-27-14, 06:43 PM
B
I will do my best to explain what i did. at the first box there is two white and two black wires. I joined two whites or black(not sure which one) to line one on the thermostat. I joined the other two to line two. then ran a black and red from the two load wires on the thermostat to the heater. again forget which colour from load one and two. then separated the two black wires in the heater and joined a black two one and a red to another. i asume there are two black and white wires as one in a jumper to next one.
Old 12-27-14, 06:53 PM
So at the first box you need to check the two whites and two blacks you have paired.
You should measure 240vac between the white and black pairs.
pcboss's Avatar
The red and black you ran cannot be run in free air. They need to be in a cable or a conduit.
T-stats are wired to the L1 and L2 terminals for incoming power. T1 and T2 are the switched power.
Old 12-27-14, 06:57 PM
It sounds like he using that red jacketed NM cable with the red and black conductors.
Old 12-27-14, 07:04 PM
B
So if i put a meter on the two blacks they should be 120 and the two whites 120 to equal 240. The black and red wires are in an insulated cable.
CasualJoe's Avatar
Received 185 Upvotes on 166 Posts
Have you verified that power is getting to the thermostats? Was the wiring disconnected at the circuit breaker before the renovation?
Old 12-27-14, 07:17 PM
B
yes it is getting there and registering on one of the live wire testers. then if i turn the thermostat on then shows the wires are live at the heater itself.
Old 12-27-14, 07:21 PM
ray2047's Avatar
If you mean a non contact tester the results are meaningless. You need to use an analog multimeter.
Old 12-27-14, 08:59 PM
So if I put a meter on the two blacks they should be 120 and the two whites 120 to equal 240.
Almost..... put one probe on the white wires and one probe on the black wires. You should measure 240vac at that location. If you don't then the problem is between there and the panel.
Old 12-28-14, 10:50 AM
CasualJoe's Avatar
Is that a non-contact tester?
Old 12-28-14, 11:02 AM
B
yes no contact tester. I guess i will buy a multimeter
Old 12-28-14, 11:06 AM
CasualJoe's Avatar
They have their place, but troubleshooting is not one of them. Seems there are several people a week posting with confusing problems because of using these things.
Old 12-28-14, 05:05 PM
B
Mastercraft Smart Meter | Canadian Tire
would this be an ideal tester. Thanks for everyones help by the way.
Old 12-28-14, 05:53 PM
ray2047's Avatar
Way more expensive then you need to spend and digital even that expensive don't have the circuity to reject induced voltages. An $8-$15 analog meter would be a better choice.
Examples: http://www.amazon.com/GB-Electrical-...og+multi+meter
http://www.amazon.com/Mastech-YG188-...og+multi+meter
GE Analog Multimeter-50952 - The Home Depot
