Lighting and Wall Help
Received 0 Votes
Long story. Bought my home with a almost completed basement. One of the wall outlets was not fully secured in the wall, and while I was working on something else my dogs were goofing off and hit the unsecure outlet. This caused a short and the lights in the basement went out. I replaced the outlet and when I flipped the breaker back on, success! Lights came back on, and the power to the outlet is fine. So after finishing this I went to turn off my lights via previously working switch , and the lights did not respond to the shut off. The only way to turn off the lights now is to flip the breaker.There are 2 sets of lights that were affected, one is working fine. The other is not, and I cant figure out why. I'm by no means a pro, but have done simple electrical jobs like this before. This particular set of lights has three switches in different places to use, all tested with my AC power tester and power is definitely going to the switch. I would appreciate any help or advice!
Welcome to the forums.
Well sure there is power at the switches or the lights wouldn't work at all.
I'm thinking ceiling lights staying on...... not receptacle.
If you look at the second photo you can see the tab is missing between the screw and the hole for the screw.
Needle nose pliers can be used to bend the tab back and forth until it breaks out.
