Reload this Page >
Car battery booster emits whine that changes when plugged in
Old 12-29-14, 06:09 AM
L
Received 8 Upvotes on 8 Posts
i have a Peak jumper pack that is a compressor too. stopped using it a year or so ago as one of the features didnt work, i presume the compressor but i forget. anyway, i wake up today to a steady high pitched noise coming from it. for the fun of it i plugged it in for a second and the pitch momentarily changed. i also tried turning each function on and off and nothing changed. the battery charged life shows nothing when i press the button. no easily determined way to pop it open and disconnect the battery either
i put it out in the breezeway in case it explodes or something but what the heck is this noise?
Old 12-29-14, 07:01 AM
W
Received 60 Upvotes on 52 Posts
Battery Booster
Could be a cooling fan...................
Old 12-29-14, 07:20 AM
L
didnt know they had them. will have to look for 'fins' on the outside then
Old 12-29-14, 08:00 AM
L
nope none............weird
Old 12-29-14, 08:35 AM
Received 3,422 Upvotes on 3,068 Posts
Maybe some type of low battery warning. Is there a model number on that Peak booster ?
From their website....
Reverse polarity indicator/alarm – Alarm and light if you do not hookup correctly to your vehicle (if hooked up incorrectly your battery could explode)
That's probably what you are hearing with a low battery. Maybe charging it for a while will take care of it. If not the battery may be on it's last legs.
Old 12-29-14, 09:30 AM
L
so if i plug it in it wont blow up or anything? just weird sitting in closet over a year and all of a sudden does this and turning any switch on or off doesnt affect it. my bet is the compressor died as i did buy a new one last winter. wouldnt have done that unless i was broken
pkcobj is the model
Old 12-30-14, 09:49 AM
L
day 2 ...no signs of letting up. when i finally go back to work ill have to put it in the yard away from the house
Old 12-30-14, 02:25 PM
Received 74 Upvotes on 69 Posts
Probably the low battery alarm
I have a Peak jump starter and they have a little plug (Which always falls out and gets lost) to enable the low battery alarm. To disable the alarm you have to put that little plug back in which as I said probably got lost
Looking at you model the low battery disable plug is right below the charging jack
Old 12-31-14, 05:00 AM
L
oh it was in. but not firmly...stopped now..thanks...amazing. so the battery was good for over one year without any use, pretty wild
