Help! Need to wire new ceiling light to electrical box having many wires!
I have tried and tried, but can't figure out how to connect a new ceiling light to the ceiling electrical box. My ceiling electrical box has eight (8) wires (not counting ground wires) coming out of it. From what I can tell, they appear to be as follows:
a. 1 black (hot) power source
b. 2 black that connect to 2 separate wall outlets
c. 1 black that connects to the light switch (which is a dimmer light switch)
d. 1 white that corresponds to the black power source
e. 2 white that correspond to the 2 black that connect to 2 separate wall outlets
f. 1 white that corresponds to the black that connects to the light switch
In addition, there is 1 white wire and 1 black wire coming out of the ceiling light that I am trying to install.
When I connect a to b, and d to e, the wall outlets work fine. However, I can't figure out the combination of connections to also power the new ceiling light.
Any suggestions would be appreciated.
Thanks.
Thanks.
Welcome to the forums.
You have a 4" round ceiling box with 4) two wire cables coming in and you are adding another one for five cables ? Isn't the box a little over filled ?
Switch
I think you have a switch loop. Tell us what wires are in the switch box and how they are connected.
Connect A + B + F (The white "F" wire should be recolored to black, white or red)
Connect D + E + white of the fixture.
Connect C to the black wire of the fixture.
PJmax, thanks for the suggestion.
I tried it, but unfortunately it did not work. In addition, the wall outlets no longer had power.
Just to be sure, I also tried the following alternate configuration:
Connect A + B + C
Connect F to the black wire of the fixture.
Unfortunately the same outcome as with your suggestion.
Any other tips or suggestions?
Thanks.
Connect A + B + C
Thanks.
PJmax, actually, the wall outlets do work for your configuration. So it's just the light fixture still not working. I am wondering whether it could be the light switch itself that is broken.
FINAL UPDATE: it turns out that the switch was broken. Don't know what the issue was, but when I disconnected it and installed a new switch, everything worked.
Thanks again, PJmax, for providing me with the configuration.
