Removing old pipe with wires in it (outside home)?
Old 01-04-15, 09:45 AM
Hi,
So I have an old rusty green pipe with wires at the top that seem to be taped off.
Im assuming they were cut and a new (updated to code) live wire replaced it.
This pipe runs down the house to the basement. I need to remove it so I can finish building the garage roof and this pipe is in the way.
Can I take my grinder and cut the pipe and contents inside of it?
Here is a video of the pipe.
Removing green pipe? - YouTube
Old 01-04-15, 10:40 AM
CasualJoe's Avatar
Received 173 Upvotes on 156 Posts
Sure, why not? I would advise you find the other end of the pipe and be sure the wires are disconnected before you start cutting though.
